in the same spot as the cow bell with addition of the wiring harness they suggest. But I have yet to actually use it instead watch for the idiots and slow down or get away from them fast.
Might want to play with what you've got. Clean the contacts and adjust the gap. Many times a weak horn becomes quite a bit stronger with just a few minutes of twiddling.
Can't go wrong with a Mini Beast. Plug and play 15 minutes. I even went to HD and got a small HD stick on winged madallion and stick it on there. You should have seen the parts guys rifling through their parts book to find the new HD Air Horns I drove up with...LOL. I never said they were HD, mind you, they are all about wanting to sell something, so there ya go. Oh...Loud too!
I remember a forum member posting a horn system that was a loud horn you wired into your stock horn . The loud horn was mounted under the saddlebag . it also was tied into your head light/running lights . if you pushed the button once it sounded the stock horn if you held the button down it started blasting the loud horn and flashing your lights in unison. DOES anyone know what this horn system is called
