Code cause by rear speakers
Old Feb 24, 2007 | 11:23 AM
ultra2006's Avatar
ultra2006
Default Code cause by rear speakers
Anyone had this happen and what was the cause, dealer said I threw a code for the rear speakers cant find problem or why it happen.
Old Feb 24, 2007 | 11:33 AM
PEZ's Avatar
PEZ
Default RE: Code cause by rear speakers
Hey
Mine did this. HD has released several upgrades for the HK radio. They get uploaded by burning a CD and putting them in you CD player. I have all of them. I believe the first upgrade fixes the rear speaker code issue. Drop me an email and I will send the files to you. Give your dealer s**t for not doing this for you. HD supplies all the updates to the dealers, and they are supposed to do the uploads free at every service. I have only ever talked to 2 people who ahd the upgrade done without asking........
PEZ
Old Feb 24, 2007 | 12:34 PM
dgriffith's Avatar
dgriffith
Mine has never had a download since new. build date 4/06. Is this something I need to be concerned with ? Thanks Dan
Old Feb 24, 2007 | 01:01 PM
Silverearl's Avatar
Silverearl
I did the upload and there are a couple things to remember.. First you have to say the files to disk and the write speed of the disk can not be higher then 8x. If it is then the radio will lock up and that is a major pain in the arss.... Trust me.. I have noticed that one thing that changed was that when you are using the front headset and adjust the volume you also see the back headset volume. The old way you did not see it.. That is one thing that I liked about the old version. It would tell me when the back headset was plugged and when it was not.. Now I can not tell... but it is something that I will have to figure out now that I have uploaded the new version.. If you would like more info let me know..
Silverearl's Avatar
Silverearl
Old Feb 24, 2007 | 01:07 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
ORIGINAL: PEZ
Hey
PEZ
You can get updates here. http://www.harley-davidson.com/cp/moar/en/software.asp
You only need to install the latest ... not each one in succession. I've never had a problem with it.
Old Feb 24, 2007 | 08:54 PM
oley55's Avatar
oley55
PEZ, my radio will not pick up any AM staitions at all. does that sound like software or hardware? it's till under warranty, but what a pain.
ORIGINAL: PEZ
Hey
PEZ
Old Feb 24, 2007 | 09:34 PM
BIGCHIEF's Avatar
BIGCHIEF
Oley;
Although I am not Pez, that sounds like a bad antenna to me. Check the end in the tour pac first, then make sure the antenna is actually plugged into the radio. It is possible to pick-up some FM with a bad antenna, but AM needs a good antenna.
Old Feb 24, 2007 | 10:43 PM
dgriffith's Avatar
dgriffith
Thanks for the info.
Old Feb 24, 2007 | 11:05 PM
PEZ's Avatar
PEZ
I agre thatyou need to check to continuity of your antenna--am should be no issue.......PEZ
