2013 Ultra Primary adjustment procedure
Old 07-21-2013, 10:16 PM
wooduster's Avatar
wooduster
wooduster is offline
2nd Gear
Default 2013 Ultra Primary adjustment procedure
On my bike there is no inspection cover for the primary adjuster thingy. Ok not the right term but you get the point, do we have to remove the whole primary cover to do this? I didn't see anything with the clutch cover off to indicate you could do it from that area. Or did Harley finally use a self adjusting chain tensioner?
Mark
Old 07-21-2013, 10:23 PM
Tinman265's Avatar
Tinman265
Tinman265 is offline
It's automatic..... No adjustment...... But it can get the chain too tight and damage the inner primary bearing......
Old 07-21-2013, 10:30 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
Check this thread for the most popular replacement.
https://www.hdforums.com/forum/touri...-pictures.html
Old 07-22-2013, 04:18 PM
wooduster's Avatar
wooduster
2nd Gear
Kind of what I thought Thanks. I notice other 2013's make the same whine as you gear down, must be the chain being a bit tight.
foxbrow
04-09-2014 07:31 PM
jacknthebox
05-15-2010 10:58 AM
deadman77
07-13-2009 02:52 PM
nhbouncer
05-04-2009 02:15 AM
njesus
06-12-2008 03:33 PM
Quick Reply: 2013 Ultra Primary adjustment procedure
