Auto Primary Chain Adjuster
Old Jul 13, 2009 | 07:26 AM
deadman77's Avatar
deadman77
Default Auto Primary Chain Adjuster
I have an 05 TC.
I am considering upgrading to the auto adjuster.
Is it difficult to install my self? Pull only the primary cover off?
How long do they last?
Is it worth the $$
Thanks MikeM
Old Jul 13, 2009 | 09:33 AM
KumaRide's Avatar
KumaRide
They will last a long time.. 100k miles? Never heard of one failing.... Some say its worth it, others do not. Not a big deal to check and adjust the chain tensioner every 5k miles. It encourages you to visually inspect the chain and gears. I would spend the money on something else. Something you can see and really appreciate...
Old Jul 13, 2009 | 10:03 AM
xxxflhrci's Avatar
xxxflhrci
An unneccessary luxury, IMO.........In 75k miles, I have only had to adjust my primary chain once.
Old Jul 13, 2009 | 10:06 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Unnecessary. I have actually heard that the auto adjuster has been known to keep the primary chain so tight that it wears out your primary bearings. Adjusting the chain is simple. I have adjusted it on my 2002 once. Plus, as long as you have the adjustment window in the primary, there is not need to remove the entire primary cover.
Old Jul 13, 2009 | 02:38 PM
priceamp's Avatar
priceamp
I think you’ll find that on a new bike, the primary chain will stretch a little and thus need to be adjusted somewhere around 10K miles, after that, you’ll likely be good to go for 50K unless you pop the clutch a lot.
Old Jul 13, 2009 | 02:52 PM
ChromeJunkie's Avatar
ChromeJunkie
I had one on my 06 Heritage Classic and ended up taking it off because it ratcheted up so far the chain was way too tight. I have the old adjuster on now and haven't had to adjust it in quite a while. Spend that $100 on something else.
sgw1064
Jan 8, 2023 09:19 PM
1harleyman
Nov 8, 2020 09:11 PM
natural gasser
EVO
16
Aug 22, 2019 09:43 PM
azharleyrider86401
Apr 8, 2011 05:43 PM
sidewayzls1
May 16, 2008 06:55 PM
