powercommander
Old Aug 12, 2013 | 07:35 PM
pled55's Avatar
pled55
Default powercommander
theoretically if a person has a sert,racetuner or sepst already on the bike
and they loose the tuner or the box that connects to the bike to tune with
i forget what it's called .could that person put a powercommander on the bike and tune from there or do they need to have the ecm put back to stock.
Old Aug 12, 2013 | 07:45 PM
TUCCI's Avatar
TUCCI
I wasn't aware you can put the ecm back to stock that once the sert is married to the ecm theres no divorce. If you try to put a PC on top of everything else your going to cause conflicting data and its not recommended.
Old Aug 12, 2013 | 09:13 PM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
My bike had a sert with it. I put a PC V and AT on. No problems. Bike runs great, not too hot, slight burble on low RPM decel.
AFAIK, the PC modifies the signals from your ECM to the fuel and timing to suit the parameters you've set. It doesn't matter what the parameters are from the ECM.
Old Aug 13, 2013 | 12:15 AM
bagman1's Avatar
bagman1
I just had my motor redone, it has a sert from the first build and a PC was installed on the new build, from the way it was esplained to me (and I forgot half of what was said) the PC overrides the sert, and yes it cant be removed, there is no divorce option. 3k miles and no issues. We will see how it does in a few weeks trapsing through Az, Co, and UT in the hot climates.
Old Aug 13, 2013 | 01:33 PM
pled55's Avatar
pled55
thanks to all of you .i was kinda thinking it could
be done but wasn't so sure
Old Aug 13, 2013 | 01:36 PM
pled55's Avatar
pled55
thanks for the response and have a safe trip
out there.
CSC5150
Jan 1, 2011 05:54 PM
ubreal
14
Sep 20, 2008 09:19 AM
cabowabodude
Oct 12, 2007 06:49 PM
arachman
Jul 23, 2006 12:11 AM
