Seafoam - magic ? really ?
Old 09-19-2013, 02:40 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Default Seafoam - magic ? really ?
I see Seafoam touted often in posts as a cure-all for bugs on windscreen to flat tires..well, not really but any fuel system query gets posts about seafoam.
Do we REALLY know that it helps.
Here is why I ask;
I did use seafoam in the fuel system of my old truck- which right away failed emissions ( high CO).
I did call the seafoam co. and left a voice message- i got a call back almost right away, and they avised that i should try to run all the seafoam through, then a couple more tanks...then retest...and the truck passed.
I have always been skeptical about magic fluids and lubes.
what say you all?
Mike
Old 09-19-2013, 02:53 PM
rpbrown's Avatar
rpbrown
rpbrown is offline
I use Seafoam about once a month to help keep the injectors cleaned out.
A few years ago my bike started stalling out when I would come to a stop. A buddy told me to put in the Seafoam and I did. It hasn't done it since. Coincidence, maybe. But I think it works. Magic, I wouldn't go that far.
Old 09-19-2013, 02:58 PM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
I use seafoam, STP, Marvel's in mine. I'm not sure which one is best, or if any of them make a difference.
Old 09-19-2013, 03:03 PM
riteway's Avatar
riteway
riteway is offline
Been using it for years.....I think it helps.....
Old 09-19-2013, 03:05 PM
Uncle Chester's Avatar
Uncle Chester
Uncle Chester is offline
Pour some in a shot glass and drop it in a mug of beer then chug it down. Gauranteed to clean your system out.
Works ok in you bike also.
Old 09-19-2013, 03:06 PM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
I've been using it or something similar for years. I feel especially compelled to use it now that there is ethanol in almost all gasoline.
Old 09-19-2013, 03:27 PM
ninja12's Avatar
ninja12
ninja12 is offline
I've used it in everything with a gas motor.
Usually can tell the difference same day.
Sea foam tune up (google it) got my daughters car threw inspection.
Put a can in an old zero turn with a weak motor, turn out motor ok carb was dirty.
Miracle no,,,but it is the best fuel system cleaner i ever used!
Old 09-19-2013, 03:32 PM
RAP's Avatar
RAP
RAP is offline
I use it to keep the carbon build up down. And clean the injectors.
Old 09-19-2013, 03:41 PM
Bagger_Vance's Avatar
Bagger_Vance
Bagger_Vance is offline
I use it in everything (vehicles, bikes, ATVs, snowmobiles, mower, weed eater, snow blower, ect) and buy it by the gallons at Advance Auto. With an online discount code I think it's about $45 per gallon and pick it up at a store. I add about 12oz to the oil and drive about 25 miles before I can my oil in my vehicles. I also run it through my intakes about 1 a year to clean off deposits on the tops of my pistons. It's worked magic on a couple vehicles by doing that but do it with caution.
Old 09-19-2013, 03:42 PM
t. sawyer's Avatar
t. sawyer
t. sawyer is offline
when I first got my used 07 sg the top end noise just seemed to much to me. I put seafoam in a few times and bingo! much better. Truck got so it had alittle unsteady idle. bingo! fixed that. now I put it in everythinghat runs on gas. I think it great stuff. Not magic, but almost...hehe
kroozeabout.
Quick Reply: Seafoam - magic ? really ?
