Motor Options
Old Dec 15, 2013 | 02:54 PM
PDDGM's Avatar
PDDGM
Default Motor Options
My 05 Ultra is going to have over 100,000 miles by next spring. I would like to have the motor overhauled, but want a little more getty up than I have now. Presently, stock displacement, Andrews 24 cams, SA air cleaner.
What are my options with out being to radical or lose dependability?
Old Dec 15, 2013 | 03:09 PM
Prime Rib's Avatar
Prime Rib
I'm interested in this topic as well Right Worshipful. I'm gonna tag it.
Old Dec 15, 2013 | 03:38 PM
jmacdonald5's Avatar
jmacdonald5
..I would just do a 95 (HD), or 97(Fuel Moto), kit...bump the compression up to 10:1, and a mild flowing of the heads..(05 heads already have bee-hive springs), and pick out a cam that works for what riding style you want to do...simple..proven..not radical...
Old Dec 15, 2013 | 03:42 PM
jus2anoyu's Avatar
jus2anoyu
A good 95" will run with most stage 1 103" bikes. Talk with a reputable builder and let him know your riding style. Be sure to express that dependability is high on your wish list.
Old Dec 15, 2013 | 03:49 PM
Bachus's Avatar
Bachus
Give Wes a call @ CycleRama.
http://www.nightrider.com/biketech/street_tc_engine.htm
To me this looks like the ultimate street motor for a bagger!
Dan B.
Central Ks.
Old Dec 15, 2013 | 04:11 PM
grbrown's Avatar
grbrown
We have HDF sponsors who are engine builders and can help you chose, just call into the Tech Engine section and take a look around. I assume you are planning a bottom-up rebuild, which adds the possibility of using a stroker crank. Along with a big-bore conversion that could really open up some possibilities!
Old Dec 15, 2013 | 04:19 PM
qtrracer's Avatar
qtrracer
I might as well say it, call fuel moto, there do all you fm fans feel better now, lol.
Old Dec 15, 2013 | 04:36 PM
DTTJGlide's Avatar
DTTJGlide
I say if it's running good & not using much oil to just keep riding it, it should be worth another 50K anyway.
Old Dec 15, 2013 | 07:25 PM
0ldhippie's Avatar
0ldhippie
If ya are gonna have it completely gone though It wouldn't be much more to go with welded stroker crank and 107 kit. Ya could pick up some better flowing 103 takeoff heads with ARCs to save on headwork. Maybe add some andrews 57 cams and smile on down the road with a more dependable power house. There are some good builders on the forum.
Old Dec 15, 2013 | 08:25 PM
jus2anoyu's Avatar
jus2anoyu
Not sure where you are, but please consider these....
GMR performance (steve)
Kirby at vtwin performance
HILLSIDE cycles (Scott)
