1998 speedometer
Old Dec 16, 2013 | 06:14 PM
Horser72's Avatar
Horser72
Default 1998 speedometer
I've got a 1998 flhrci speedometer that the led went out on. I got a speedo from an 2007 RK(67033-04b) I can't find the right plug to fit it. Can anyone help?
Thanks
Old Dec 16, 2013 | 07:00 PM
larsfum's Avatar
larsfum
Originally Posted by Horser72
I've got a 1998 flhrci speedometer that the led went out on. I got a speedo from an 2007 RK(67033-04b) I can't find the right plug to fit it. Can anyone help? Thanks
The 2007 may not work without at least some modifications. The 1998 Speedo is mechanical and is driven by the front wheel. The 2007 is electronic, and uses a sensor in the tranny. There may be an adapter or you can use an electronic rear wheel pickup, but then you will still have to require the correct plug for the back of the speedometer.
JLeclainche
Aug 1, 2018 09:40 AM
Horser72
Dec 17, 2013 11:57 AM
El Chiguete
Electrical/Lighting/Alarm
Apr 21, 2013 08:44 AM
ambrose
Oct 22, 2010 02:52 AM
softtail69
Feb 17, 2007 01:57 PM
