Speedometer calibration help needed..
Old Jan 6, 2014 | 07:06 AM
mdanehart's Avatar
mdanehart
Default Speedometer calibration help needed..
I have a 2007 FLHX 113 CI controlled via Powercommander 4 / USB.
The teeth on the transmission pulley were changed from 32 to 30, by the former owner.
According to the odometer compared to my car the same distance traveled was 6 tenths of a mile more on the Harley, over a 7 mile stretch.
Doing some research I discovered that the ThunderMax Self Tuner has software menu options for this modification, but don't have the spare $ at this time.
Any suggestions besides changing pulleys?
Old Jan 6, 2014 | 07:15 AM
vbx07's Avatar
vbx07
Call fuel moto or get a power vision tuner.
Old Jan 6, 2014 | 10:59 AM
bagman1's Avatar
bagman1
Baker has a speedo calibrator that you install in the deutsch communication harness between the trans and the speedo. It has an up and down button to calibrate the speedo. I have an earlier dakota digital one but havent tried it yet, as I havent found the connection yet. I think its under the battery housing frame, but Ill get to that eventually.
I have the same mod and my speedo is 4-8 mph off depending on speed. I think the cost is about $130
Old Jan 6, 2014 | 11:14 AM
DTTJGlide's Avatar
DTTJGlide
There are several different add-on units to calibrate the speedo, Dakota Digital makes one also, as stated above DJ PV has the ability as does the TTS tuner, most of the add-on ones are $100+.
Old Jan 6, 2014 | 11:21 AM
mdanehart's Avatar
mdanehart
Thanks folks , this gives me a starting point....
azchopper
Jun 11, 2017 01:18 PM
tc88hog
2014-2024 Touring Models
Dec 29, 2014 05:38 PM
Rich67
Jun 16, 2014 01:14 AM
stockglock1927
Mar 24, 2014 01:46 AM
djl
Exhaust System Topics
Dec 1, 2012 02:00 PM
