Hidden antenna
Old 02-20-2014, 10:31 AM
ConfuciusSay's Avatar
ConfuciusSay
ConfuciusSay is offline
Received 2,530 Likes on 685 Posts
Default Hidden antenna
Anyone using a hidden antenna in their fairing? How is the reception? I want to scuttle my antenna from the rear of my bike. Any info, including installation issues will be appreciated.
Old 02-20-2014, 10:44 AM
rs87277's Avatar
rs87277
rs87277 is offline
I heard that this antenna is no good so i just did the hidden antenna mod for free
Old 02-20-2014, 10:45 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
antennas work best when posted near vertical
amplified antennas will amplify noise at the same ratio as radio frequencies ( these are offered on ebay etc.)- so if your radio is picking up 40% static and 60 % music, an amplified antenna will give you the same 40/60 proportion
if you are in an urban area and stay fairly close to the broadcast tower this may make no difference to you
I get pretty good results with a $8 pepboys rubber stubby mounted using the relocate bracket that comes with the detachable kit
mike
Old 02-20-2014, 10:53 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 22,110 Likes on 8,499 Posts
Not a whole lot of science about the antennas. MKguitar is right about the antenna being vertical for best performance. The hidden antennas usually include an amplifier to compensate for the reduced length. Unfortunately, it amplifies the static as well as the radio signal, so you still aren't going to be able to pick out the weaker stations without the noise too. With the bike sitting still and motor not running, you can hear a lot of station, but once on the road, the weaker ones go away.
You can cut down the stock antenna. Look at the base of the antenna where the whip goes into a threaded base, you will see a small allen set screw in the side of the antenna base. Loosen the allen set screw and the whip can be pulled out and cut about a foot or so shorter.
Old 02-20-2014, 11:04 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
Actually there IS a lot of science about antennas, the length of the antenna is calculated for the frequencies desired- "tuned". there is a direct relationship between the length of an antenna and the frequencies that it will easily receive.
better results cutting a solid antenna ( no loading coils, no wiring wrapped around it), would be found by cutting it exactly in half or quarters. ( so the octave and 2 octaves above the fundamental)
random cuts will result in the antenna being tuned for random frequencies.
mike
Old 02-20-2014, 11:10 AM
ShrinerRider's Avatar
ShrinerRider
ShrinerRider is offline
I use the Jand Midden antenna in the fairing and have no issues. I still receive all of the stations I did with stock.
Old 02-20-2014, 12:02 PM
thirstybob's Avatar
thirstybob
thirstybob is offline
I have the HD hidden antenna and it works great. I've noticed no difference in the city or in the country.
Old 02-20-2014, 12:35 PM
yokdriver's Avatar
yokdriver
yokdriver is offline
I just tucked the oem antenna and it works just fine free mod ftw
Old 02-20-2014, 12:39 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
I use my iPod.. No need for an antenna lol
Old 02-20-2014, 12:44 PM
DeeRoe's Avatar
DeeRoe
DeeRoe is offline
mike
...so I guess the old coat hanger thing is totally out.......
Quick Reply: Hidden antenna
