Mid Range GRUNT
Can anyone advise me, I'm running a Street Glide with a stage 2 1550cc (95inch) conversion, SE 203 cams, SE air cleaner and Vance & Hines oval slipons. The bike goes really well but I want more midrange grunt. Without spending a fortune on SE heads etc, what would be the best way to go, thoughts so far are along the lines of a Powercommander 111 or SERT,but has anyone tried a Powercard? The powercard works with the load of the engine, but is not available through any dealersover here (the UK) so ordering it from theStates if it's not any good would be rather costly, whereas both the PC and SERT are proven.Does the PCmake much difference to the performance? I understand you can tweak the revs to 6200 so it should, I just need to know from someone who's done it on a ST Glide as noboby around here seems to have more than just a stage 1 tune up, boring Brits I here you say!
Keep the rubber side down
Balders[8D]
Balders[8D]
bjewell
Apr 26, 2010 06:51 AM
balders
Mar 28, 2007 05:21 PM
Anthony8858
Nov 3, 2005 05:55 PM
