EFI to carb
Engine mount (with slot for choke) ……. 16315-99
Choke cable ……. 29229-88D
Choke elbow ……. 27580-88
Choke boot ……. 27582-88
Intake manifold ……. 27613-99
Manifold seals ……. 26995-86B
Seal ring (carb/manifold)…… 27002-89
Ignition Harness ……. 32435-00
Manifold sensor (MAP) ……. 32416-10
Manifold sensor seal ……. 11291
Retaining clip ……. 38723-99
Retaining clip screw ……. 68042-99
Stock Petcock- 61338-94D
Stock CV40 Carb- 27412-99D
You will also need the ignition module of your choice
You may want to add a new set of throttle cables to the list. Your current cables will work but will be about two inches longer than than the stock ones for a carburetor model.
I did this conversion recently on a 2001 Road King and am very pleased with the noticeable increase in torque and throttle response compared to an M&M tuned with a Screaming Eagle Race Tuner.
As I understand the -99 version of the carb has changed internal passages and the earlier version -96 or earlier is preferred.
I have only used the earlier versions so don;t know if that is correct or a fable.
a perfect used CV carb is easy to find as many riders replaced with other brands.
the key to examining a carb is if the plug over the idle adjust is intact, then it hasn't been monkeyed with
nightrider.com
biketech
cv carb tuning
has good info
mike
nightrider.com
biketech
cv carb tuning
has good info
mike
