Stator Replacement Question?
Old May 4, 2014 | 08:54 PM
TSD's Avatar
TSD
Default Stator Replacement Question?
Do I have to replace the rotor when I replace the stator. I removed stator today and it is fried!!! Thanks , Tim
Old May 4, 2014 | 09:13 PM
dawg's Avatar
dawg
Now would be the time to upgrade to a 45 amp rotor if yours has the 38 amp rotor. Otherwise, if the rotor is in good shape with the magnets, etc. then no you don't have to replace it
Old May 4, 2014 | 11:20 PM
mkguitar's Avatar
mkguitar
...and do not use air impact tools on the comp nut- it can knock the magnets loose...and destroy the new stator.
mike
Old May 4, 2014 | 11:36 PM
booch's Avatar
booch
I just had my stator replaced, compensator replaced with the new SE compensator and new rotor, and oil pan gasket replaced.
Since they replaced the oil pan gasket they had to change oil and tranny fluid. All done under ESP for $50. This alone made the ESP worth it, never mind the tranny rebuild and starter replacement last year.
pjb
Shovelhead
Aug 21, 2017 05:43 AM
MDodson
Mar 16, 2010 05:03 PM
wiseguyups
Aug 30, 2009 07:40 PM
twistedcherokee
Aug 13, 2009 07:53 AM
Z
Aug 19, 2007 08:24 PM
