Need some help ASAP!
Old May 29, 2014 | 04:35 PM
Mixter's Avatar
Mixter
Default Need some help ASAP!
I was removing the front tire of my 2010 street glide and noticed that one of the screws that holds the axle bracket on the right side of the wheels was broken in half....
Is there any way to fix it or do in need a new fork leg?
Old May 29, 2014 | 04:37 PM
Mixter's Avatar
Mixter
not sure why the picture is rotated but the pic needs to be rotated so the bolts are pointing down
Old May 29, 2014 | 04:42 PM
dgoodbmw's Avatar
dgoodbmw
Default stud
There is no reason why the piece left cannot be removed thru several different ways and a new stud installed. You can try a jam nut method, a vise grip method, some heat gun or other ways to loosen the remaining piece. It is not a crisis.
Old May 29, 2014 | 04:45 PM
fabrik8r's Avatar
fabrik8r
its a stud with threads on both ends, double nut it or use vise grips to grab it and thread it out of the leg and replace with a new stud.
Old May 29, 2014 | 04:47 PM
14GuineaPig's Avatar
14GuineaPig
try part #20
http://www.granitestateharleystore.c...7eFAIRING%5cKB
45998-73 STUD (right-hand) | FC/FF/FV/KB/KE/KH
Old May 29, 2014 | 04:58 PM
Mixter's Avatar
Mixter
Ah gotcha thanks guys....I thought it was actually part of the fork...didn't realized it could be removed.
Old May 29, 2014 | 05:07 PM
Mixter's Avatar
Mixter
they were powder coated so it looked like it was all one piece....Love this Forum thanks Guys!!!
Old May 29, 2014 | 05:12 PM
sgdiesel's Avatar
sgdiesel
That stud thread looks very badly distorted and reduced diameter (necking). I suspect it was subjected to some serious overtightening
Old May 29, 2014 | 06:48 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Use some heat from a heat gun just in case it was tightened with red Loctite.
Old May 29, 2014 | 07:05 PM
clarkchriston's Avatar
clarkchriston
I would pull them both and replace them. If one was over torqued, then I would bet both were. A local Indy suggested to me that I replace them every other time I take the fork clamp off. The bolts get stressed every time you torque, and remove. Cheap enough bolt and easy to do so why not.....then again it is just the front wheel.
