2006 Ultra classic compression ratio
Old 07-14-2014, 09:30 PM
Madcop's Avatar
Madcop
Madcop is offline
Default 2006 Ultra classic compression ratio
Will soon be changing out the stock cam chain tensioners to the SE hydraulic conversion. I already have the true duals, SE air cleaner and stage 1 download. While in there i want to do a cam change. I was looking at the Andrews TW37B, but in reading the specs it recommends a 9.0 to 9.5 compression ratio. My service manual says I have 9.0:1 but if I Google 06 ultra classic spec its says i have 8.9:1. So I am wondering which one is correct and if the Andrews TW37b work if i do in fact 8.9:1.
Old 07-15-2014, 05:26 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Andrews make several suitable cams and members have used plenty of them. If you use Advanced Search in this Touring forum, in titles only and search for 'Andres', you will find plenty of light reading. Their 48 and 57 get regular mentions and those threads may help you pick the most suitable.
Old 07-15-2014, 07:29 PM
fidel's Avatar
fidel
fidel is offline
the 37 need more compression 9.6 9.8 or really soft bottom check for andrews 48
Madcop
Engine Mechanical Topics
07-16-2014 10:36 PM
roaddr
10-20-2012 08:00 PM
msere123
Exhaust System Topics
08-10-2012 12:03 PM
cthowards
11-05-2009 08:08 PM
twohats
01-10-2007 12:55 PM
Quick Reply: 2006 Ultra classic compression ratio
