Cam Advise
Old Aug 10, 2012 | 08:55 AM
msere123's Avatar
msere123
1st Gear
Default Cam Advise
I talked to the dealer yesterday about more passing torque for my 2006 Ultra Classic (88ci). I just need a little more umph to pass or get out of the way of cages. He recommended swapping the cams as a start for a low cost alternative. Any advise or recommendations is greatly appreciated.
Old Aug 10, 2012 | 09:27 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
What is done to the bike already? Without an air cleaner and pipes, cams will do little to nothing for you. Stage 1 set up may be all you need, assuming you do not have it already.
Old Aug 10, 2012 | 09:35 AM
fxdxrdr's Avatar
fxdxrdr
both Andrews and S&S sites have descriptions of their cams. Depending on what other engine mods you may have and what kind of power band you want one of their descriptions should help you find a cam that will give you what you are looking for.
Old Aug 10, 2012 | 09:54 AM
msere123's Avatar
msere123
1st Gear
Sorry Guys,
I do have the Stage 1 kit and I also had the race tunner installed and mapped. Other than that all stock.
Old Aug 10, 2012 | 12:03 PM
djl's Avatar
djl
Andrews 21 and retune; you will like it. Check those tensioners; maybe change to the CYCO shoes
http://www.harleydavidsontensioner.com/
Upgrade those inner cam bearings while you are at it; cheap and it adds about 30 minutes to the job. You will have to decide if you want to retain the OEM pushrods or go with adjustables.
sskimber
May 30, 2016 10:17 AM
bigskyroadglide
Engine Mechanical Topics
May 16, 2016 09:07 AM
Cray2751
Dec 15, 2011 07:43 AM
GPHDXLC
11
Aug 5, 2010 02:38 PM
4merRacer
Oct 18, 2007 01:31 AM
