2008 road king fork oil change
Old 07-15-2014, 07:52 AM
customglide57's Avatar
customglide57
customglide57 is offline
Default 2008 road king fork oil change
is it a matter of draining the oil while working the forks to "squeeze" the oil out and then refilling with the proper amount. or is some special technique and tools required? tks,
Old 07-15-2014, 08:05 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
When servicing your own bike a copy of the factory service manual usually answers all such questions! That's the first tool required. If you have drain plugs in your fork sliders then your approach should be fine. Hopefully someone will chime in with the correct process for filling them.
Old 07-15-2014, 05:44 PM
customglide57
took your advice and went to the Harley shop today and bought a service manual. i'll not bother anyone with basic questions any longer. tks, ride safe folks.
Old 07-16-2014, 09:47 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
We'll still be here to help!
Old 07-16-2014, 10:55 AM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
No special tools required. Get the bike up on a jack, remove fork caps, then remove drain plugs and let drain. Each fork tube holds 10.8ozs. I use a funnel with a hose connected to it to refill forks. Replace drain plugs and pour 6ozs in each fork and let stand for 15-20 mins. Then pour in remaining 4.8ozs in each fork, replace fork cap and your good to go.
2010 Limited with some stuff
ballbreaker69
05-25-2013 02:05 PM
Chopman
01-30-2013 06:37 AM
elwoodto
04-14-2012 02:32 PM
oldtech
02-26-2012 04:25 PM
joe v
02-12-2007 10:10 PM
Quick Reply: 2008 road king fork oil change
