Looking at getting a Triglide
Received 3,963 Likes
If not, take a tire gauge and get those rear tires down to between 20-22 PSI. That alone will make it ride much better.
Most Dealerships are now putting the tires at 26 PSI, but there are still some that are setting them at 36 PSI. As you can see in the video below, neither of those are the correct setting, and it makes a huge difference.
Mary and I have been riding Tri Glides since 2011....including a trip up to the Arctic Circle (roads don't get much worse than in the Yukon!) We have steadily been working at getting them more and more comfortable.
We have our Tri Glide set up where it is as smooth as most HD 2 wheelers, and smoother than many HD 2 wheelers.
Feel free to peruse our different YouTube videos, we have quite a few on getting a Tri Glide set up for Comfortable All Day riding.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
The following 5 users liked this post by DK Custom:
ChopperBill (05-22-2023),
heavymetalthunder (05-13-2023),
nobodyknowsme (05-13-2023),
stixvrad (05-21-2023),
talkingrock (05-13-2023)
I watched the DK video above and decided to give it a try on my CVO trike. Even with the low profile rear tires it made a noticeable improvement. I lowered the pressure to 21 pounds. After an hour or so of riding I started getting a pop up on the screen that my pressure was low and the tire light lit up. Since that will drive me crazy I’m going to put the pressure back up.
I didn't bother with test rides before I bought my trike as my research told me that you can't appreciate the trike experience on a short test run. Also, my choice was either a new trike or giving up my helmet! My trike was a harsh ride at first and the only modification required was with the driver. It now rides as smooth, if not smoother, as my previous two wheelers!
I'm still new to Trikes. Only have a few hundred miles on one. Wasn't sure at first if it was a good decision to make the switch. I wanted to get a feel for it before I chanced anything. Only thing I've changed so far is lowering the rear tire pressure to 22 psi. It made a huge difference. After I saw the article by Lehman Trikes on tire pressure, it all made sense.
The more I ride, the more I like it. The reason we bought a Trike is it was the only way my wife would ride any more, on 3 wheels.
BigD48 (05-21-2023)
The ONLY thing you gain in going from a two-wheeled bike to a trike is stability.
You lose ride comfort, speed, handling, good gas mileage, etc., etc., etc,
A lift kit and new adjustable shocks from DK along with lowering your rear tire pressure down to 20-22 lbs. does make a difference in the ride but adding that extra wheel does increase the chances of hitting more potholes.
The following 2 users liked this post by Don60:
5wheels (05-23-2023),
hydraglide (05-29-2023)
I brought up a trike this last winter. Wife almost insisted I get one, and she doesn’t even ride! As far a ride, my Freewheeler was pretty rough until I lowered the air to 20#. I also put a lift and it made some difference. I’ll add my 91 custom soft tail beat the hell out of me. I’m happier on the three wheels and have been riding a heck of a lot of more miles.
Don60 (05-22-2023)
I’ve had 2 triglides. First was a lemon, 2018, the second was 2020. There was an ultra limited in between, but due to some knee issues that was replaced by the second trike. I have since gone back to 2 wheels late last year. For me the trike was getting to boring. Riding in the twisties most of the time was fun, but it lacked the enjoyment that I ride for. The 20 was a good bike, but I just missed the thrill of cornering on 2 wheels. I’m only 69, so maybe when I get to the mid 70’s I’ll look at a trike again, but most likely a freewheeler. I found the weight of the tri to be a bit much. Good luck with your decision, enjoy it.
