First problem with TG
I checked the plugs in both mine and my dads today and the front plug came out with no problem, turned out by fingers once loose. I put anti-seeze on them and re-installed The rear plug was another story. Both turned about 2 turns and then I met resistance so I stopped and turned them back in. I called the service mgr and got a rash of crap from him which I expected, the guy reminds me of one of those nervous little yapping dogs. Anyway, he started crabbing on why did I read something on the internet and then go and try it, said I should have brough it to him and let them check it out. I told him I needed an apointment to have them pull the rear plug and put the anti-seeze on they neglected to do. He then proceded to ask me where in the manual it said to put anti-seeze on, I about come unwrapped. After our conversation I dug out the service manual to verify the service interval on the plugs and sure enough they should have been inspected at 1,000 miles on mine and 10,000 miles on my dads. I also have the page and section along with what it says in the manual about putting anti-seeze on the plugs written down so I can quote it and tell him where to find it.
Anyway, page 1-7 of the manual has a chart and it says "the table below list the periodic maintenance requirements for touring model motorcycles". The table shows in my case that at 1,000 miles the spark plugs are to be inspected. Then on page 1-47 which is the inspection instructions which tell you how to remove the spark plugs along with how to inspect and what to look for. They give descriptions on what to look for and refer to a table with pictures of examples. Step 7 of the procedure tells you to "apply Locktite Anti-Seize to the spark plug threads install and tighten to 12 - 18ft/lbs". Also on page 1-47 as part of the inspection it tells you to inspect the plug wires along with how to perform the inspection. Part of the plug wire inspection is checking the resistance with an ohmmeter. There is a chart on this page showing what the resistance for the front and rear plug wires should be along with instructions to replace them if they don't fall within the specifications. How many techs perform this step, one will never know. Just looking at the outside tells you only part of the story.
Spark plugs and plug wires are an important part of the the knock control. If the resistance of the plug wires are not within spec the ecm may detect false knock activity or not detect it when it should. As an example, last year I was experiencing some issues with my 06 Ultra. I use a SERT as the tuner so I connected it to the bike and my laptop and performed some data runs. Out of the data runs I was seeing knock activity that I know was not correct, it was pulling upwards of 13 or more degrees of timing out. After checking the resistance of the plug wires I found they were out of spec. I replaced them which solved the problem which was confirmed by performing another data run.
The best money one can spend is buy the service manual. For my 06 I have the service manual, parts manual which is good because of the parts explosions. I also have the electrical trouble shooting manual for the 06, some of these are not needed unless your going to do lots of your own work. For the Triglide I would get the above mentioned service manual which is for those with the 09's along with PN 99601-09 which is the service manual supplement for the Triglides. For those with 2010 models they'll need PN 99483-10 touring service manual and 99601-10 which is the supplement for the trike. If your going to do some home service work spend the money on the proper tools such as a torque wrench in some cases it may require one in in/lbs and one in ft/lbs.
Maybe I'm wrong but this could be the next issue Harley has to deal with. I'd almost bet once they are get more claims through warranty or other means they will start applying Anti-Seize at the factory upon engine assembly and expect the dealer network to follow the documented service procedures. The rear cylinder is running way to hot for 2 dissimilar metals to coexist and not gall without anti-seize.
You guys got me worried so I went out and checked ours. Both plugs backed right out. Bare metal for me to. Probably should have pulled em when I did the 1,000 mile or before I put the PC V on it .....to have a look see.... but never did. Put some anti-sieze on em and put em back in. Good thing cause usualy with me when something can be F'ed up I'll get one of the F'ed up ones.
Shoot! If there was a lottery with only 100 tickets available and I had 99 of them you could bet I'd have every one except the winner.
As I mentioned yesterday, Dealer B was great in dealing with our problem and did all they could to get warranty coverage, even considering paying for it themselves (which would have been way too much to ask, in my opinion, since they had nothing to do with the problem). By the way, Dealer B is Cajun HD in Scott, LA. They have been perfect in their handling of my problem.
We shall see how Dealer A comes out, but they have always been excellent, too, and I expect them to do everything they can this time.
Only the HD company rep was a problem. He has basically just stiff-armed us. That's OK; I have a long memory. I'm starting to review BMW brochures.
You're right about having the service manuals. I have one for the 2008 models, but not the 2009 models yet, since we just traded for them. I will get the 09 manuals soon.
For once I kind of can't blame HD for taking that stance. They expect their servicing dealers to perform the work per procedure. In this case it looks like dealer "A" has a technician that is not performing the work as it is outlined in the service manual so in reality they are at fault and responsible to make reparation to you for the damages cause by their technicians short comings. The big question to ask is if they skipped the plug inspection what else did you pay for that didn't get serviced?
