98 softail engine problems
Old Mar 19, 2007 | 03:57 PM
jennifer burton's Avatar
jennifer burton
Stage III
Default 98 softail engine problems
We have a 98 softail custom which has had on going problem for a long time with back firing, rough bogging idle, missing.... We have had it tested several times and have ruled out, spark plugs/wires, battery and connections, module, ignition switch. Also, we replaced the coil. We have had it re-jetted. Nothing is working to eliminate this problem. We have the stock carb and are thinking if we should change that out??? If so...which would you recommend and will it work with the original air cleaner. Any other suggestions of problem solving would be appreciated!!!!!!!!!!! Thanks, Jennifer
Old Mar 19, 2007 | 04:21 PM
Road Warrior's Avatar
Default RE: 98 softail engine problems
Welcome from Montana. I can't answer your question, but someone can. Try the technical section as well.
Old Mar 19, 2007 | 04:23 PM
skipit's Avatar
skipit
Welcome from California!!
Old Mar 19, 2007 | 05:13 PM
Blackbird's Avatar
Blackbird
[sm=icon_cheers.gif]
Welcome to the welcome forum from Omaha, NE.
Old Mar 19, 2007 | 05:36 PM
fmbeach's Avatar
fmbeach
JB,
Check out the EVO section of this forum. Except for missing I had similar problems caused by an intake leak and corrected by replacing the neoprene seals ($2.00/parts & about an hour labor). Air/fuel mix might be rich as well. What color were the plugs?
Old Mar 19, 2007 | 05:43 PM
Guilty's Avatar
Guilty
Welcome from Salem, Oregon
Old Mar 19, 2007 | 09:21 PM
jennifer burton
Stage III
Thanks for the reply....the plugs always check out fine!!
Old Mar 19, 2007 | 09:59 PM
randy78045's Avatar
randy78045
Big Kahuna HDF Member
Welcome from Laredo, Texas...
Old Mar 19, 2007 | 10:00 PM
HDWG's Avatar
HDWG
Welcome from INDY
Old Mar 19, 2007 | 10:17 PM
Big Dog's Avatar
Big Dog
Hello from Kansas and Welcome to the PARTY!!!!!!!!!!!
