Question
Old Aug 17, 2021 | 11:30 PM
03fattyaz's Avatar
03fattyaz
Default Question
Can you mount a tire that calls for a 4” wide rim on a 3”? And if so would it make it wider with a lower profile?
example: a 5” bias ply that calls for a 4 inch rim would be 127mm, would the same tire on a 3 inch rim end up being 6” or roughly 150?
trying to find a bias ply rear that would be lower profile and wider than the 5.00x16 shinko that I have on the front.
03 Fatboy (stock as far as this goes)
Thanks.
Old Aug 18, 2021 | 06:33 AM
Wide06's Avatar
Wide06
Originally Posted by 03fattyaz
...example: a 5” bias ply that calls for a 4 inch rim would be 127mm, would the same tire on a 3 inch rim end up being 6” or roughly 150? ...
No. A narrower rim would have a tendency to make the tire profile more narrow and taller.
...trying to find a bias ply rear that would be lower profile and wider than the 5.00x16 shinko that I have on the front...
This would take going from, for example, a 130/60 tire to a 150/50 tire. The first number is the width (on the suggested rim), and the second number is the profile.
Going from a 130/60 to a 150/60 would be wider AND taller.
As far as how wide or narrow of a wheel you can put a tire on...that varies and the manufacturer will have a recommended wheel width range. If one width is listed, then that's the width used to measure the tire size and profile.
Old Aug 18, 2021 | 09:15 AM
03fattyaz's Avatar
03fattyaz
Thanks. That makes sense. Guess I’ll have to go with the same tire on the back and lower the bike to keep the same stance. Or stick with a 150/60 I just don’t like any of the tread patterns I’ve seen.
robwlf10
Wheels/Tires
May 26, 2021 03:00 PM
CSS_FXD
Apr 12, 2013 06:35 PM
LX HEMI
Dec 31, 2009 08:09 PM
05 fxst
Mar 9, 2008 11:01 PM
T_Rob666
Sep 20, 2007 11:59 AM
