Brake Problem
Old Jun 5, 2011 | 09:33 AM
The Breeze's Avatar
The Breeze
Default Brake Problem
I have a 2001 FLHR the front brakes don`t work the way i think they should,I pull on the lever and it moves about half way to the bars before they start to apply the brakes I have tried to bleed them the old fashion way and tried to use a vacuum pump and i get air passing buy the bleeder fitting and not much fliud volume and the lever never gets any stiffer. I have not seen any fliud leaks anywhere ? Any ideas ?
Thanks The Breeze.
Old Jun 6, 2011 | 12:20 PM
rh8234's Avatar
rh8234
Do you have the stock (from new) brake lines on it? If so, is it possible thet the brake lines are swelling when you squeeze the brake lever? Just a thought.
Old Jun 6, 2011 | 12:22 PM
grbrown's Avatar
grbrown
There is a thread with tips on bleeding brakes in the DIY forum. Bleeding brakes is one of those things we should only do when the stars are in certain alignments and the gods have been appeased for a month of Sundays. Sometimes it goes right, sometimes.....
Best of luck, but persistence pays.
zgunnar48
Apr 30, 2015 07:08 PM
Scooter68
Jul 24, 2009 08:26 AM
Aussiecraig
Jul 14, 2009 12:40 PM
MotorSgt
Mar 18, 2009 05:15 PM
Bikerboy50
Oct 2, 2008 08:14 AM
