Need help wiring speakers to Soundstream PN4.520D 520W 4 Channel
Old 02-12-2015, 06:47 PM
evildxtreme's Avatar
evildxtreme
evildxtreme is offline
2nd Gear
Default Help wiring 6 speakers to Soundstream PN4.520D 520W 4 Channel
OK guys I have researched and researched and finally came to a decision and purchased my new system setup and installed it. The only step left is to wire the speakers and ride but I am confused how to do so. Here are the details on what I've got on the bike..
HEAD UNIT: Pioneer DEHX9600BHS
Built-In Amplifier MOSFET 50 W x 4
RCA Preouts- 3 (front,rear,subwoover)
Crossover Netwok- HPF/LPF
audio output- 4 ohms
AMP: Soundstream PN4.520D 520W 4 Channel
Picasso Nano Series 4-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 130 watts x 4 chan.
4 ohms, Bridged: 260 x 2 chan.
FAIRING SPEAKERS: Infinity Kappa 62.11I
Peak Power Handling 225 watts
RMS Power Handling 75 watts
Sensitivity 95 dB
Frequency Response 45 - 25000 Hz
Impedance (Per Voice Coil) 2 ohms
TWEETERS IN SMALL GAUGE HOLES: Infinity Reference 1031t
Sensitivity 93 dB
Frequency Response 2500 - 21k Hz
High-Pass Crossover Frequency 2500 Hz
RMS Power Range (Watts) 2-50
Peak Power Handling (Watts) 150
Impedance (Ohms) 2 ohms
REAR 6X9"S IN HARD BAG LIDS: Kappa 693.11i
Sensitivity 96 dB at 2.83 volts
Frequency Response 35 - 30k Hz
RMS Power Range (Watts) 5-110
Peak Power Handling (Watts) 330
INTERCONNECT RCA CABLES on front and rear from the deck to amp.
I'm sure I will run the 6x9's to the left and right rear channels on the amp but not sure how to run the tweets and 6.5" speaker to the front to channels. also if there is any stereo gurus on here which i'm sure there is I need help setting the gains on the amp with a multi-reader. I have no clue on the whole OHMS Law.. Much less doing it with the tweets and 6.5"s running together.
Any help would be great as I want my girl to be right. lol
Old 02-12-2015, 06:58 PM
CaCruizin's Avatar
CaCruizin
CaCruizin is offline
I have run the tweeters in parallel with the front speakers with no problems in the past....
Old 02-12-2015, 07:10 PM
evildxtreme
2nd Gear
Thought about doing that but from what I've read that will change it to a 4 ohm dependence which is less power in the front. Another thing is the tweeters are reference and have a in-line crossover on them. I believe that will effect the 6.5's. I have wired a few cars for subs in the past but I have no experience with midst.
Old 02-13-2015, 06:15 PM
just plain john's Avatar
just plain john
just plain john is offline
Try it without the tweeters first and see how you like it. The Kappa's are on the bright side as it is.
Old 02-13-2015, 09:37 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Totally agree!
Old 02-14-2015, 01:06 AM
AAWAV's Avatar
AAWAV
AAWAV is offline
Originally Posted by Gannicus
Totally agree!
Plus 1... they are bright.
Old 02-14-2015, 04:21 AM
evildxtreme
2nd Gear
Ya should have bought component speakers. Ordered the tweeters after the fact.
How about the volt readout for those speakers on the amp? I downloaded an ohms law app but don't understand how to I'm put the values.
Old 02-14-2015, 05:14 AM
Juice's Avatar
Juice
Juice is offline
re-read it, nevermind
Old 02-14-2015, 09:27 AM
Munkee's Avatar
Munkee
Munkee is offline
As others have said you won't need them and even if you did there will be no problems having them parallel with the front. Don't worry about the technical stuff here. If you were adding another pair of 6.5's then I'd be more concerned. If you don't believe it hook up your kappas on their own...then add the tweeters and see If you notice a difference in power to the kappas. But again you wont need them
Juice
Audio Systems
60
08-21-2019 11:19 AM
rgsboogie
Audio Systems
11-30-2018 08:43 PM
Budda109
Audio Systems
02-10-2018 01:47 PM
Morel00
Audio Systems
18
09-12-2017 09:06 AM
cpita
Audio Systems
14
07-04-2014 04:01 PM
Quick Reply: Need help wiring speakers to Soundstream PN4.520D 520W 4 Channel
