Antenna splitter
not too sure about that and I would think no based on theory but allows for the removal of the whip without losing FM reception altogether. I've done it on bikes here and noticed no difference in reception with both connected but also no degradation either. Just more a "creature comfort" than anything else.
Just need to keep in mind that FM is tuned by length of mast and ground points so no way a shorty antenna or an in fairing antenna is going to be able to reproduce the signal strength of a tuned antenna mast. Just gives you "some" reception.
Years ago, car manufacturers got in on the "fad" of diversity antennas. That lasted about as long as in-windshield antennas did. It simply didn't work.
M Oclaf (01-24-2023)
What type of splitter are you talking about? All splitters have an insertion loss, not that it matters much if you ride in the primary coverage range of the stations you listen to. With both am and fm bands being so far apart frequency wise, it gets complicated trying to keep a conjugate impedance match for both bands through a splitter. If your in fairing antenna is horizontal and the rear antenna is vertical then yes, it will be beneficial to you and work as a quasi diversity antenna for fm only. In order for it to work on the am band the antenna separation would have to be thousands of feet long.
I'm having second thoughts about even trying the two antenna combo. Because the in fairing HD antenna is connected to a power supply and grounded through the radio body I suppose, So if I tied the two together with a common connector that would electrify the other cable all the way back to the mount, Right? and ground to the frame there? Dosen't seem like such a good idea now.
