Tuner/Exhaust question?
Old 11-22-2014, 06:47 PM
blastonerski's Avatar
blastonerski
blastonerski is offline
Default Tuner/Exhaust question?
I have a 2005 Super Glide Custom (EFI) with a Thunderheader and tuned with a V&H Fuelpak. I bought it with all these upgrades from a private seller.
It runs good and sounds good, but I think it can be tuned better.
Now...I purchased a Bassani 2-1 exhaust, my question is do I have to remap it, re-tune it, etc? Is the V&H Fuelpak good enough or should I get a different tuner (i.e. Screaming' Eagle Pro Tuner, TTS, etc?
Old 11-22-2014, 11:57 PM
latrobedyna's Avatar
latrobedyna
latrobedyna is offline
i like my power vision tuner , I use that or a TTS tuner unless money no issue then i get a thundermax
Old 11-23-2014, 03:38 PM
maddghost's Avatar
maddghost
maddghost is offline
You might have to change some settings on the fuel-pak, but if you can sell it and re-invest in something with a little more flexability then I'd recommend that since apparently one must be lucky to get what they need from a FP.
Old 11-23-2014, 05:22 PM
wastedranger's Avatar
wastedranger
wastedranger is offline
Call vance and hines and tell them what you have. They may or may not be able to give you a setting. Most of their settings are for there exhausts. There are better tuners out there but I believe it depends on what you want to get out of your bike. Dealer here is charging upwards of 2k for stage ones. That's not worth the gains if you ask me. I run a fuel pak with no trouble and I would recommend v&h and will continue to purchase thier products.
Old 12-13-2014, 05:49 PM
blastonerski
Thanks for the info guys!
Old 12-13-2014, 06:48 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
A Fuel-Pak is not really a tuner per say. Get a S/E, PV, or TTS if you're planning on doing any upgrades to the motor in the future. If all you have on your bike is the basic Stage 1 set up, a Fuel-Pak with the appropriate download or "Flash" should suffice for your bike.
Old 12-13-2014, 11:09 PM
blastonerski
OldEnuf2NoBtr.....yeah just swapping thunderheader to bassani exhaust and stage 1 air cleaner kit...no engine upgrades. so is the fuelpak good to go?
Old 12-14-2014, 06:35 AM
wastedranger
You will need to adjust the fuel pak. You have to email V&H your setup or call Custer service and tell them what you have. They will give you the settings. If you would have their exhaust it's as easy as looking it up. But other brand exhausts need customized settings. They should be able to give you one to try and then help you tweak it from there. No download or flash as fuel pak is a piggy back unit.
Old 12-20-2014, 11:10 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
If all the bike has is different pipes, don't waste your money on a tuner... unless you're gonna change your intake and then cams.
That being said... if you know you will do that in the future, get the TTS.
Myglide13
02-12-2014 09:43 PM
vivid black
02-03-2014 03:38 PM
The Korean
06-10-2013 08:35 PM
Evil_keeps_me_young
12-27-2010 08:17 AM
MilesOD
04-22-2010 11:49 AM
Quick Reply: Tuner/Exhaust question?
