A good chrome cleaner will remove heavy oxidization and should be used/tried before using other more aggressive methods. If the cleaner doesn't then try the 4 ought steel wool
Try flitz ball and autosol. When I bought my 07 SB, both rims have surface rust, I use Flitz mini ball and autosol, cleaned them in 20mins. Flitz mini is small enough to get into tight spots like between laces and hub.
If they are really bad, Nothing cleans better than mothers and shoe laces and some hours of your time. After that apply a couple of coats of wax to ensure coverage and then routine cleaning to remove brake dust dirt and road grime with occasional waxwings. Lyndall Gold Z brake pads will help with the brake dust rust problem.
Try dipping a piece of aluminum foil in water, rub it on your chrome parts, it will create a paste through some kind of chemical reaction, it actually works pretty good.
