James Gaskets
Old 08-18-2016, 07:42 PM
just plain john's Avatar
just plain john
just plain john is offline
Default James Gaskets
I'm gathering parts for an upcoming 95" build, and am looking for a top end gasket set, preferably one with .030 Cometic head gaskets. Any complaints about James Gaskets?
Old 08-18-2016, 08:09 PM
just plain john
Something like this, or is there a better alternative? https://www.denniskirk.com/genuine-j...prd/264008.sku
Old 08-19-2016, 04:45 AM
msocko3's Avatar
msocko3
msocko3 is offline
I've never had any issues with James gaskets, I haven't tried their MLS head gaskets tho, always used Cometic.
Old 08-19-2016, 06:11 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
James Gaskets are our 'go to' gaskets at the shop. If for whatever reason they are not in stock at the distributor, we use Cometic. Both companies make great gaskets...
Old 08-20-2016, 04:36 PM
djl's Avatar
djl
djl is offline
Received 2,061 Likes on 1,518 Posts
CYCO, a division of US Seal, sells quality gasket sets for about half the price of a Cometic set, about $50; I have used many with good results. CYCO does not sell retail or to the general public so one must set up an account to order.
Old 08-20-2016, 05:09 PM
just plain john
A closer look at the James Gaskets MLS head gasket says it's a .036, not the .030 I was looking for, so I ordered up a Cometic set. Thanks all for the replies.
Old 12-30-2019, 03:41 AM
cuclainne's Avatar
cuclainne
cuclainne is offline
6th Gear
Hi All, I am installing heads on my 2007 Dyna, have James Head Gaskets. There are no marking on the gaskets to should which way is up. Thoughts and assistance greatly appreciated. Happy Holidays
Old 12-30-2019, 05:56 AM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 4,011 Likes on 2,002 Posts
There's a front and a rear...i put raised embossed area around the alignment dowel facing up. Make sure you follow cometics torque sequence and not the factory.
Old 12-30-2019, 06:02 AM
cuclainne's Avatar
cuclainne
6th Gear
SB, the gaskets I have are James, they look the same on both sides with the exception of the fire ring. It's thicker on one side. I believe the thick side should go down, looks like that on the OEM gasket I removed.
hdHuck
EVO
08-16-2014 06:20 AM
roadgliderick
09-24-2012 12:39 AM
borncountry
06-01-2012 09:26 PM
Sheets1958
09-02-2011 05:54 PM
iknowyoueazyryder
Ironhead
02-18-2008 05:25 PM
Quick Reply: James Gaskets
