Help! Head Gasket problem
Old Sep 2, 2011 | 10:15 AM
Sheets1958's Avatar
Sheets1958
Stage IV
Default Help! Head Gasket problem
The stock head gaskets on a 2005 1200 are fiber. The o-rings don't fit in the holes, on the gasket over the dowels. Fit the dowels fine. The book says they go under the head gasket. That raises the head gasket off the cylinder deck? Starnge. I thought Ok that's what the book says. Put it together, fired it up and the gasket blew out on that side of the head. Any ideas? When I took the heads off the olk gasket were all but fused into the metal. The o-ring were in tact.
Old Sep 2, 2011 | 02:51 PM
dibe's Avatar
dibe
If you get some cometic gaskets you can eliminate the orings all together
Old Sep 2, 2011 | 04:46 PM
SportsterBob's Avatar
SportsterBob
S&S Head Gaskets don't use O-Rings either...You may have a superceded replacement set of gaskets...
Old Sep 2, 2011 | 05:54 PM
pnw_hd_rider's Avatar
pnw_hd_rider
The new replacement head gaskets don't use the O ring anymore.
roadgliderick
Sep 24, 2012 12:39 AM
borncountry
Jun 1, 2012 09:26 PM
Fl Jimbo 05
Aug 11, 2011 10:11 PM
rivercityslim
EVO
Nov 16, 2009 02:50 PM
iknowyoueazyryder
Ironhead
Feb 18, 2008 05:25 PM
