Oil Change Question
Old Sep 2, 2011 | 02:51 PM
brutalbrad's Avatar
brutalbrad
Default Oil Change Question
I'm trying to learn to work on my bike. i hate the fact that i don't know anything about my bike other than how to ride it.
I'm starting out with my oil change. this may seem very trival to a lot of people but i'm new to this. My question is once i've drained the Oil out pull off the old filter. Then i pure a couple oz into my new filter and attach, next do i want to reattach the drain hose back to the muffler mount or should i pour a little oil in first to remove air from the hose.
Trying to determine if trapping air in the drain hose will cause a problem.
I'm doing my 20k service with help from a neighbor. I would ask him but he is on vacation and i will not bother him with this.
just tryin to learn to wrench a little thanks for the help.
Old Sep 2, 2011 | 02:54 PM
petemac's Avatar
petemac
Sounds like you don't have a touring bike so I can't answer your question. But I'd highly recommend getting a service manual if you want to start working on your bike. Money well spent.
Old Sep 2, 2011 | 02:57 PM
brutalbrad's Avatar
brutalbrad
I have a 2003 sportster 1200XL. And i defiantly have a manually; mentions issues with trapping air but not very clear on how to avoid it or what will happen.
Old Sep 2, 2011 | 02:58 PM
brutalbrad's Avatar
brutalbrad
maybe i'll post this on the sporty forum as well.
Old Sep 2, 2011 | 03:14 PM
rooti's Avatar
rooti
Brad I had a sporty for two years and read the same thing. I asked a few experts and they told me as long as you put oil in the filter and smear some oil on the filter gasket with your finger you are good to go. I did it for two years and never had any issues. Next they will be telling you to burb the sporty before you put it to bed....
Old Sep 2, 2011 | 03:27 PM
parabellum_9x19's Avatar
parabellum_9x19
Unless I'm mistaken, the air in the drain hose should just bubble right up into the reservoir where there is always air anyway.
I agree that it is a good idea to start the filter with a bit of oil in it, but as soon as you start the bike it should purge all air from the system in the first few seconds anyway.
Old Sep 2, 2011 | 04:15 PM
brutalbrad's Avatar
brutalbrad
Ok this helps. much appreciated. lookin for advice from people that have the experience.
Old Sep 2, 2011 | 07:09 PM
Sgt. Fury's Avatar
Sgt. Fury
If you try to pour oil up the drain hose and then clamp it back on the plug, you're gonna make a mess.
Old Sep 2, 2011 | 07:27 PM
SportsterBob's Avatar
SportsterBob
Any air will find it's way to the top of the oil tank and the oil pump will laugh at any air headed it's way due to volume/flow.
deuce_streetbob
Apr 11, 2013 08:01 PM
KeiSki
Jun 4, 2011 08:10 PM
eviltwin415
May 21, 2010 12:55 PM
kpb46
May 26, 2007 10:56 AM
Ragin_Republican
Mar 20, 2005 04:00 AM
