Question for the painters
Im no painter but I have a friend who is and he did a nice job on my 02 Super Glide's ghost flames. He wet sanded the clear, sprayed on the ghost flames then clear coated over that. Looked good and held up for 3 years until I traded it in. I assume it held up for a lot longer after the trade
I would imagine that a painter would be able to just sand down the clear and shoot over it if you want to keep the existing color. Find a good painter in your area and ask, that's the best thing you can do. After working in a body shop for a while, there's no replacement for someone who really knows how to lay down paint.
When you find a good painter, they should be able to tell you exactly what they want to do to make it right. Guys that know what they're doing don't want to put their name on something that looks bad.
yes but make sure the fluid tip in your gun Is big enough for the flake depends on what size flake
If Teagan decided to do the flake it has probably been done already since he asked about it 5 years ago. He hasn't been active on the forum for 2 years. Still, that's a good information.
Oh and to answer the OP's question, metal flake in clear is not something I would do due to the flake size and wanting it all to be under the clear.... what you CAN do is put pearl in the clear for a similar effect.... the pearl is so much smaller that it is smothered in the clear
If you really want metal flake you can do it in an intercoat
If the underlying paint/clear is in good condition, wash, degrease, sand with 1000 wet and prep for top coat
