Throttle cable adjuster seized
Old 04-24-2009, 12:03 AM
crepe's Avatar
crepe
crepe is offline
Default Throttle cable adjuster seized
I attempted to adjust the slack on my throttle today, only to find that the throttle adjuster does not turn clockwise or counter clockwise.
Here is what I did
1)pulled back the rubber guard
2)unscrewed the jam nut away from the adjuster
3)attempted to turn the adjuster with no avail.
The idle cable also has the same problem.
Anyone know how to fix this?
Old 04-25-2009, 07:41 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
You could try a penetrant like PB Blaster or just replace the cable.
Old 04-27-2009, 02:58 AM
crepe's Avatar
crepe
crepe is offline
problem fixed. I turned the jam nut as far away from the adjuster as possible then turned the adjuster counter-clockwise. Then you the good ole twist the adjuster clockwise then clockwise trick until it loosened up. Once the throttle and the idle cables were adjusted I applied a little antiseize.
Khibbs
04-15-2018 02:56 PM
damager1
10-30-2015 07:05 PM
sp9997
04-22-2013 06:31 PM
carterw65
03-01-2012 03:32 PM
dynakeith
08-26-2006 10:09 PM
Quick Reply: Throttle cable adjuster seized
