2014 Iron - Throttle cable stretched?
Old Apr 13, 2018 | 04:54 PM
Khibbs's Avatar
Khibbs
Default 2014 Iron - Throttle cable stretched?
2014 Iron with 5K on her. Upon installing my Hammer 1250 kit the instructions (great instructions by the way) mention that you should double check that your throttle is opening the throttle body all the way to the stop.
Mine doesn't and I've adjusted it as far out as it will go and I'm still an 1/8 off the full throttle stop. Has this cable stretched that much and have others run into this?
I assume a new cable is one solution but what have others done?
Old Apr 13, 2018 | 05:31 PM
shanneba's Avatar
shanneba
Did you adjust both the cables?
Make sure the idle cable is not caught on the throttle body where the end of the cable sheath ends. It should be down in the throttle body touching a spring. I have seen mine get caught on the sheath before adjusting the idle cable.
Loosen BOTH throttle cable lock nuts.
Turn in both adjusters to make the metal cable housing at the twist grip the minimum length.
With the handle bars straight ahead-and the twist grip at full throttle-
Gently turn adjuster on throttle control cable counterclockwise
until throttle cam touches throttle cam stop. Release throttle grip.
Turn adjuster counterclockwise an additional 1/2-1 turn. Tighten jamnut on throttle
cable adjuster.
With the handle bars placed to full right-
Turn adjuster on idle the control cable to lengthen sleeve until end of cable
housing touches the spring within cable guide at the throttle body.
Make sure it returns fully - test with the engine idling, turn handlebars lock to lock and confirm the engine speed does not increase.
This picture is a carb but the EFI throttle body is similar, the enlarged portion shows the cable sheath into the housing touching the spring-
EFI is in the bottom picture.
Old Apr 14, 2018 | 04:05 PM
Khibbs's Avatar
Khibbs
Thanks for your detailed instructions here. I did adjust both cables the first time but figured it was worth a second shot following your process. I confirmed that both cables were properly seated in the throttle body properly.
Unfortunately when I turn the adjuster on the throttle cable counterclockwise I run out of threads before I can get the cam to hit the stop. I ended up making a very small spacer to sit down in the sleeve and I was then able to get it to hit the stop and finish the process.
Old Apr 14, 2018 | 05:01 PM
apache snow's Avatar
apache snow
Did you give the other cable enough slack when you were trying to get it to hit the stop.
Old Apr 15, 2018 | 02:56 PM
Khibbs's Avatar
Khibbs
Yes, thanks for double checking. I made sure that the other cable wasn't holding it back. I simply couldn't make the throttle cable short enough with the adjuster to get it to hit the stop. Weird but it must have stretched a bit over the years. I doubt the Frisco bars have anything to do with it but who knows.
damager1
Oct 30, 2015 07:05 PM
sp9997
Apr 22, 2013 06:31 PM
Big Hog
Exhaust System Topics
Jan 24, 2010 09:20 PM
kurtlange
Jan 24, 2007 03:01 AM
HDF Tech
Jul 18, 2005 12:22 AM
