changed grips now no fuel pump.
Old 08-09-2012, 08:05 PM
09hdrdr's Avatar
09hdrdr
09hdrdr is offline
6th Gear
Default changed grips now no fuel pump.
i recently changed the grips on my 09 fat-bob and now bike wont start, the fuel pump wont come on to pressurize the system & the engine light does'nt come on ,the bike will crank but not fire. the fuel pump will run if i jump a wire from batt. to fuel pump fuse.
Old 08-10-2012, 02:28 AM
scotty3's Avatar
scotty3
scotty3 is offline
Yes but the fuel pump fuse gets powered from a relay that is activated by the ECM when it gets power from the RUN/STOP switch on the RHS controls
Sounds like you have pinched a wire when doing the RHS controls up.
So undo the RHS and check the wires first.........
Then check all your fuses especially the ECM fuse and check with a multimeter as visual just does not cut it sometimes.
Old 08-10-2012, 06:18 PM
Dallas 13's Avatar
Dallas 13
Dallas 13 is offline
Likely pinched a wire in the switch housing.
Old 08-10-2012, 11:36 PM
09hdrdr's Avatar
09hdrdr
09hdrdr is offline
6th Gear
thanks i have already checked the rhs wires about 200 times ha ha... & the fuses & the clutch switch. the check engine light does'nt even come on .
Old 08-11-2012, 02:41 AM
scotty3's Avatar
scotty3
scotty3 is offline
You might have checked them and you might have missed something.
It was working before you touched it and now it's not working so that suggests to me that you buggered something up and can't find the problem to fix it.
You might have to take it someone who can spot your mistake ha ha
Old 08-11-2012, 08:24 PM
09hdrdr's Avatar
09hdrdr
09hdrdr is offline
6th Gear
ha ha i know that icould have missed it , & yeah some fresh eyes on it might help, but there is no one to take it to close to where i live... & its hard to push through the mountains ha ha ,,
Old 08-11-2012, 08:35 PM
09hdrdr's Avatar
09hdrdr
09hdrdr is offline
6th Gear
could it have caused a grnd. problem switching from stock rubber grips to chrome & rubber ???
Old 08-12-2012, 10:57 AM
Dallas 13's Avatar
Dallas 13
Grips, themselves, don't change the grounding in the electrical system.
I understand you've checked eveything; have you checked the switch function with a meter? I have seen switches die when tampered with, even a little.
Scott E Dawg
05-27-2019 11:17 AM
stal94gt
27
03-19-2016 05:10 PM
wborden
05-06-2014 01:59 AM
09hdrdr
11
08-07-2012 08:20 PM
sicksuperglide
01-02-2009 09:17 AM
Quick Reply: changed grips now no fuel pump.
