Ironhead A place to talk about Ironheads.
ignition switch wiring
Old 06-13-2017, 12:09 PM
707airbrush's Avatar
707airbrush
707airbrush is offline
Stage II
Default ignition switch wiring
trying to find a wiring diagram for a 1997 XL 1200 S Sportster
Someone tried to change this bike to a bobber and hacked up the wires. The accessory wire has not power. I found 3 wires going to the ignition switch and one of them was broken loose but i cannot tell where it should go. The switch is not marked with where the wires should go.along with no color code on the switch i cannot tell.
Old 06-13-2017, 12:47 PM
yellowstone kelly's Avatar
yellowstone kelly
yellowstone kelly is offline
Looking at an online wiring diagram for "1997 All Models" of Sportster, it looks like there should be three wires going to the ignition switch.
1. The solid red wire brings power to the ignition switch from the main circuit breaker.
2. The red and gray wire goes from the ignition switch to the 15A Accessory fuse, then feeds power to many places on the bike from that fuse.
3. The red and black (or dark blue) wire goes to the starter relay and also to the other three fuses.
I can't find where it shows which wire goes to which terminal of the switch, but if you have a volt meter you can find out from the diagram which terminals get power when you turn the key to the accessory and ignition positions.
Here's part of the wiring diagram for '97 Sportsters that shows the ignition switch and the three wires that connect to it.
By the way, you posted this in the Ironhead Sportster forum. Ironheads were only made until 1985. You might have better luck posting in the newer Sportster forum...
Old 05-03-2018, 10:36 PM
Ctrumbly's Avatar
Ctrumbly
Ctrumbly is offline
Stage I
Default Good post
Attachment 517715
excellent info.
1995 softail
01-31-2021 09:44 AM
MJR35
08-04-2018 04:30 PM
Reef Rider
01-23-2012 04:18 PM
crawfordcl
09-15-2010 10:52 AM
rgm
Custom Models
12-10-2007 09:12 AM
Quick Reply: ignition switch wiring
