Primary Chain
Primary Chain
Thinking about changing out the stock adjuster for bakers attitude adjustment chain adjuster. Now for advice do you really have to pull the compensating sprocket and chain out to get the new adjuster in there? 2012 Road Glide still stock except for cosmetics and comfort. Might swap out header pipe this year to beat the heat.
Just got THE call two days ago, just trying to decide if I grab a Barnett clutch to go in at the same time...looking forward to a sturdy well designed comp!
If you are using the SE Comp you will need a T-70 Torx socket to remove it and a torque wrench capable of final torque rating of 170 ft/lbs. You will also need either the primary locking tool or some have used a block of wood. Lastly if you remove the clutch you will need a 1 3/16 (confirm) socket to remove the clutch nut which is a left hand thread.
Yukon42
2014-2023 Touring Models
04-27-2019 06:58 PM
JustDave71
11
06-12-2010 11:08 AM
Ramboamt
01-18-2009 10:41 PM
Paul32730
12-15-2007 10:43 PM
