Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
pulsating clutch lever
Old 06-22-2015, 08:24 PM
treasuresoutofdarkness's Avatar
treasuresoutofdarkness is offline
Stage IV
Default pulsating clutch lever
I have a 2007 street bob
I have a pulsating clutch lever and noise from the clutch and maybe the inspection clutch door on the exhaust side. When the bike is not running the clutch lever has a bit to much slack but not enough to cause problems.
I adjusted the clutch and the cable by the book and to spec. But still have the lever issue and noise. When i ride the bike when i apply throttle the lever gains slack and when i let off the slack snaps back tight.
Any ideas?
Old 06-23-2015, 08:14 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
It's axial thrust from the helical cut gears push the shafts away from each other and when the mainshaft moves so does the clutch. Here check this out:
http://bakerdrivetrain.com/street-door
Old 06-23-2015, 09:32 AM
Stage IV
But what it broken? That plate? It never did that before? Did the bearings go bad?
Old 06-23-2015, 11:57 AM
Nothing may have broke, it's just wear, the snap rings are not sufficient to hold the shafts in place and the more the shafts move the weaker the snap rings get.
Old 06-23-2015, 08:15 PM
Stage IV
Is it a easy fix. And whats the benefit of the of the baker street door?
Old 06-24-2015, 08:31 AM
The gear set has to come out, and the street door retains the bearings with a steel plate as opposed to snap rings to keep the shafts from moving.
deacon1984
06-10-2022 07:51 AM
Whiskyjock
04-26-2018 05:45 AM
ned_pepper
03-04-2018 05:48 PM
sundancewind
09-25-2007 08:50 PM
WARG
07-29-2006 10:46 PM
Quick Reply: pulsating clutch lever
