Shovel chop rear signals easy
79 shovel chop. Was wondering if I could re install the rear signal lights off my tombstone tail light and some how wire it straight to the battery with a three way toggle switch so flip the switch left and left light blinks and so on. Is this a thing? I've never ran signals or a horn and I don't want to have hand controls on my bars. I'd like the toggle mounted so where else.
Any easy kind of temporary way of getting rear signals. My bike came with signals but wasn't wired for it so I took em off and just hand signal.
Thanks in advance.
Thanks in advance.
I've done that exact setup on a couple old shovels , you need to do a little digging to find the drilled out stand-off studs so you can run the wires internally and there's any number of small tear drop shaped lights you can use on them. Sorry no pictures , but it looks like somebody did that to that tombstone already.
Yeah I got the lights. My question was can I wore it up right to the battery? Or can you tell me how you wired yours? I'm not sure if wiring directly to battery is doable and at what point do you add the switch to the circuit and should you add a fuse?
Any diagrams or anything? Lights I have, just need help wiring it simply. Only rear signals with no bar controls.
If you want just running lights yes you can wire them direct to the light switch. Turn signals your going to have to have some kind of handlebar switches and wiring can go a couple ways depending on what you do there. Sorry but without more details on how your going do it I can't help any.
I want rear signals that would be controlled by a toggle I'll mount by my seat so at night I can flick left and the left turn blinks,flip the toggle right and so on. Basically the same as having em on the bars but by my seat. My question is I got 2 wires going to the signals(1 wire each) can I just wore it to a three way switch and the to the battery.
