2014 FXDB Wiring issue help please
I went to the dealership today and they did not have the clip in stock and were not exactly sure on ordering. I was a little frustrated. I came home and put the clip back together, put some electrical tape around it with heat shrink. It seemed to fit together perfectly.
When I did the right side I took the wires out of the electrical clip and the job was much easier. Once I threaded the new bars I them put the wires back into the clip, plugged it back in together and there was no issue.
PROBLEM: The bike turned on but there is no power to the switch housings. So I'm worried that the left side is affected from the clip that got chewed up. However, I am wondering if the left side does not work, does that default to the right side not working? Either way I have no power to the electrical.
So my options are to come up with a new clip, either from the dealership or from somewhere else. Other option is to cut both clips off and do the old school method of soldering and heat shrink.
I'm pissed.
https://serviceinfo.harley-davidson....cle/lookupForm
Check your fuses.
Do you have power to your head & tail lights?
Do you have turn signals, brake light, horn, speedometer/odometer?
Look at the easy stuff first.
Check your fuses.
Basically the power is not coming on to the switch housings. I double checked the connectors and I'm assuming the left side clip connector being chewed up is the problem and I need to find another clip (male part) to match and then wire. Or....cut both and just use butt connectors. Did some research and the clips are apparently "Deutsch connectors" or something??
You said no flashers ... does that mean the turn signals (front & rear) light up but do not flash?
Does the speedo light up? Does the odometer show the mileage?
It looks like your bike has the canbus wiring so I'm not too sure but I would look at the battery fuse again. That seems to supply power to the hand controls.
Other than that I don't think I can help.
If your bike has the canbus wiring, then cutting wires probably is not a good idea.
http://partstream.arinet.com/Mobile/...ZHDPEHgy0.html
^outpost alaska's part finder.
Shouldn't be an issue finding that male connector and getting it on order.
See if you can take a small file (maybe a nail file) and clean up all the burrs on the plastic. Maybe you can clean it up enough to get it to work while you order another connector.
Looks like part #13
http://www.docshd.com/OEMpartfinder....TCHES,_HANDLEB
Here's more places to get the connector
http://www.dragspecialties.com/produ...umber=21200661
http://www.directcycleparts.com/elec...8-p-27200.html
http://www.customchrome.com/dcm/cc/_...lla_Cables.pdf
