Turn Signal problem
Turn Signal problem
I changed my rear original turn signals on my 07 Fatboy and replaced them with aftermarket strut end ones.
First Problem is that now they seem to flash much quicker than before - is this normal ?. Or do I need to put one of those load equalise things on ?.
Second Problem - since installing the aftermarkets, the little red key on the dash stays lit from the second you use the indicators till you turn off the bike. This little red key is to do with the security system on the bike, anyone know why it would be doing this ?.
RE: Turn Signal problem
Sounds like your replacement signals are LEDs. If so, they draw much less current, and would account for both of your problems. Yes, you will need a load equalizer to resolve this. Problem is, load equalizers are resistors, and resistors generate heat. Now you have to find a safe place to wire them in where the heat won't cause any damage.
That's why I stayed away from LEDs - can of worms.
You probably need an equalizer. Try www.biketronics.com You can email them. They were very helpful to me.
Hey skulznflames, I've got the Alloy Art strut end turn signals that I'm about to install. How did you get to the wiring to install yours? I was wondering if you have to remove the fender or the tire to get to them. Also, what would be the best connecters to use. Thanks.
vanceandharley
Electrical/Lighting/Alarm
01-18-2015 02:48 PM
porkchop38
General Topics/Tech Tips
05-03-2009 10:22 AM
