Possible Security issue preventing bike from starting?
Old Jan 17, 2015 | 03:27 PM
vanceandharley's Avatar
vanceandharley
Stage III
Default Possible Security issue preventing bike from starting?
Hey guys, brand new here so hello and nice to join! I have a 2009 nightster that has been flawless since I bought it up until now. Randomly this winter when I put the key in the ignition and turned it to the on position the security light comes on as usual but then it will flash along with my left and right turn signals. Now with the turn signals they do not flash at the same time like they would if the system was activating and shut off. They will alternate and flash one after another, front and rear, left side then right. When this goes on it completely shuts out my starter and doesnt even try to turn over. If I wait about a minute it all stops but still keeps me from starting the bike. Curious if the cold weather has caused it since it started when it got colder out maybe? I was able to ride it one time after it happened a month ago or so. Any help or suggestions would be appreciated.
Old Jan 17, 2015 | 04:13 PM
Larry Davis's Avatar
Larry Davis
Not that familiar with your model, but if you have a FOB those are signs the batteries in your FOB need to be replaced.
Old Jan 17, 2015 | 06:01 PM
rjg883c's Avatar
rjg883c
I agree with Larry. Did you try entering the override code with your turn signal buttons?
If you aren't familiar with the override code/turn signal buttons, do a search because there are several(many) threads on the subject.
Ron
Old Jan 18, 2015 | 06:41 AM
wastedranger's Avatar
wastedranger
Keep your cell phone away from your fob also. It interrupts the signal.
Old Jan 18, 2015 | 10:12 AM
vanceandharley
Stage III
I appreciate all the help. When I saw FOB a light bulb in my head went off and I went and found my spare key and FOB. Turned it on and everything worked as it should and started right up. Does this mean (as it was said before) that it's more than likely just the batteries in the FOB I was using?
Old Jan 18, 2015 | 10:42 AM
rjg883c's Avatar
rjg883c
Probably, but you should take this as motivation to learn how to start your scooter if the FOB is lost, stops working, or the FOB battery dies when you are out somewhere and you NEED to get it started and your spare FOB isn't handy.
Old Jan 18, 2015 | 02:48 PM
vanceandharley
Stage III
Yes, I will definitely take the time as I have been researching and reading other threads on how to override the system and sure enough one day I will be 40 minutes from home and it will happen again. Thanks again for the help everyone!
wdatkinson
Sep 26, 2024 03:57 AM
Hero
Sep 13, 2023 02:15 PM
JonV
Jul 30, 2010 12:02 PM
0Nightster7
Jun 28, 2010 07:32 AM
onlythebest
Jan 5, 2008 06:44 PM
