I just installed the front Radiantz LED turn signals, on my 07 RoadGlide, to go with the rear led's I have been running. I now get the rapid flash turn signals after the 4th flash, along with the security key light that stays on while the bike is running.
If I do not install a load qualizer, will anything be damaged? (Other than me having to look at the red key all of the time.)
(I kinda like the rapid flash of the turn signals now!)
You should actually install the equalizer. I am not sure if any damage could be done by not installing it, but you may have a problem with the security system not working properly...???
Security system works fine. I cannot start the bike unless I have the key fob on me or I enter the personal pin# via the turn signal swith ritual.
I can get the light to go off if I enter the personal pin#. But after I turn the turn signals back on , everything is fine until it starts the rapid flashing, and then the red key light comes back on.
