Widest rear tire that will fit 04 softail standard?
Old 08-13-2009, 10:46 PM
firemanbill's Avatar
firemanbill
firemanbill is offline
Stage III
Default Widest rear tire that will fit 04 softail standard?
Am getting ready to replace my rear tire and wanted to know if anyone had put a wider one on the rear, it has a 150/80/16 on it now stock
Old 08-14-2009, 04:38 AM
Chazmanian's Avatar
Chazmanian
Chazmanian is offline
R.I.P. BROTHER
160 Metzler will fit without any mods. Anything bigger like a 180 will take some modding. Your fender is what the issue is as it isnt wide enough to hold anything much bigger than a 160 without rubbage issues.
I run a 160/60/18 on my 05'. Its nice. My optimal sizing back there would actually be a 180 stuffed into the stock fender as I'm not willing to do a wider fender as I much prefer the narrow fender due to its staying true to the original design cues of the bike. I'm skeptical that a 180 will fit and not rub on that stock fender if the bike is lowered 2".
Should I ever feel the need to go fat back there it would be a heartland type kit or twisted choppers bobber fender on a 180. IMO 200MM on these bikes looks to be a bit too fat for my oldschool taste!
I like the 18 as you can pull off a lower look without actually being as low. 160 Metzler is about the same width as a 150. If they make a 170 that would fit without but I havent ever seen one. I have about 1/4" clearence on each side when lowering the bike so the wheel tucks up into the fender. Not much room for error there!
Old 06-06-2019, 03:52 PM
samnmee's Avatar
samnmee
samnmee is offline
Stage I
Chaz, Is your 18 rear wheel stock or aftermarket?
needlevictim
06-24-2021 01:44 AM
sac95
12-29-2015 06:36 PM
stilup
10-23-2011 08:58 AM
06STRD
04-14-2011 06:43 AM
rudythumpdick
02-10-2009 12:53 PM
Quick Reply: Widest rear tire that will fit 04 softail standard?
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
