Front tire (fender)? upgrade
Old Oct 23, 2011 | 04:24 AM
stilup's Avatar
stilup
Default Front tire (fender)? upgrade
I'm looking to put a bit wider front tire on. 110/90-19
Compared to the stock 100/90-19 I don't think it should hit the front fender but I'm not sure.
I am thinking to go with a metz as I just purchased the Metz 170/60R-17
for the rear. the rear wider seems to be the same width as the stock 509 Dunlop.
What are your thoughts on installing the bigger front tire?
Thanks.
Old Oct 23, 2011 | 08:40 AM
8541hog's Avatar
8541hog
Go for it, you can always pull the front fender temporarily while you look for another if it does not fit.
Then buy a blank and drill your own mounting holes to make it fit like you want.
Old Oct 23, 2011 | 08:58 AM
Harley Tim's Avatar
Harley Tim
It will fit.... Been running one for a while now. And, by the way... If that is your first time running a radial in the rear...You're in for a pleasent supprise....No more Butt wiggle when you change lanes out on the freeway when going across the seam at the dotted line.
JoeGrapes
Jul 30, 2012 06:41 AM
WhiskeySierra
Mar 3, 2012 12:20 AM
ropin4gold
Feb 13, 2010 11:32 AM
Desertdog7
Feb 6, 2010 12:00 AM
vincent21212
Dec 22, 2007 01:05 PM
