Flat spot
Flat spot
Hello everyone, I need a little help. I have a 2012 48 bone stock except the baffles removed. When I removed the baffles there was a stumble or flat spot at low RPM's. I put a set of Xied's in and that solved the problem, this was 2 years ago. This pass weekend the stumble and flat spot came back and the bike is popping really bad. I checked for leaks and there are none and plugs look good. I'm thinking the Xied went bad. Can anyone give me suggestions where else to look. Much appreciated.
XiEDs work but have limits. Try DK Custom's Thunder Torque Inserts...they work and not costly. TTI's reduce/eliminate reversion and increases low-mid range power. Kevin at DK has videos with baffles removed with TTIs
Here is a current thread on the same subject.
https://www.hdforums.com/forum/sport...ck-pipe-2.html
Good luck with your mods...if your bike is stock except for baffle removal, the TTIs may suffice. A tuner may be overkill unless you have expendable funds or plan to upgrade your intake or do other performance mods. Have fun with it.
