Messin with baffles
Old Mar 23, 2009 | 10:49 PM
SH_01FXDWG's Avatar
SH_01FXDWG
Default Messin with baffles
I just recently installed some bct baffles. They sounded great, deeper tone. The only thing was they are louder than I would have liked. So after riding the bike for a couple days, tonight I wanted to try something before dishing out more money for the QQ series. Since I installed the bct's deeper into the pipe I took my stock v&h baffles and cut them in half and was able to put them back in the stock location. Fired it up, and sure enough it was quieter. Still has that deep tone. So I went for a quick spin. Felt really good. Did not choke it off at all, maybe even a little more torque. <--- (probably my imagination) The bike was popping a bit when I shifted before. Tonight it did not seem do do that. Although, that usually happened after the bike got good and warmed up. Tonights ride was to short for that I think. So, we'll see. Has anybody else here tried this? If any of you fill like testing it out for yourself, let me know what you think.
Old Mar 23, 2009 | 11:19 PM
chad peterson's Avatar
chad peterson
Playin with baffles is a good thing especially when you understand how they work. When I had my bassani pro 2 into 1 the baffle is louvered & wide open...lacking a little on the bottom. I made an exact copy of a propipe standard baffle & tried it. Peak numbers were the same, but the torque jumped from 80 to 90 at 2500 rpm's. Sound was a little quieter, but still had the bassani deep tone!
Old Mar 24, 2009 | 12:09 AM
JRK5892's Avatar
JRK5892
i am sure someone on here will buy those old baffles... are they 2002?
Old Mar 24, 2009 | 10:23 AM
SH_01FXDWG's Avatar
SH_01FXDWG
They are 2001. So far this little mod is working out. I went back out again for a bit. The sound at idle is great. Cruising speed is much more subtle. I'll get more riding time in this week. For sure if I end up changing the baffles out, I'm sure I can sell them here.
Old Mar 24, 2009 | 10:28 AM
Goddahavit's Avatar
Goddahavit
so the big end is screwed to the stock hole?towards the end of the pip and the front is towards the manifold just hanging in the air?
Old Mar 24, 2009 | 11:01 AM
SH_01FXDWG's Avatar
SH_01FXDWG
This pic should give you an idea what I did. The arrow points to where the bct is mounted. Also, the bct baffle is at the recommended 6" depth. So by cutting the stock baffle in half I was able to fit it in there.
Old Mar 24, 2009 | 11:45 AM
Goddahavit's Avatar
Goddahavit
ahh got it so your running both baffles...
thanks...
Old Mar 24, 2009 | 01:20 PM
paul s's Avatar
paul s
I went with the QQ's and they gave me what I was looking for, loud on the gas and not so loud cruisin.
Old Sep 18, 2010 | 03:12 PM
CRZYLGZZ's Avatar
CRZYLGZZ
Dude, can you make a video, and post it up. this is a good idea.
Old Sep 18, 2010 | 03:28 PM
blacknsilver's Avatar
blacknsilver
I did the exact same thing as you did and it does quiet it down a bit but still keeps the deep sound. The guy at BCT recommended to do this and it worked great.
