key stuck in ignition
Old 09-19-2011, 05:27 PM
ryanlberg's Avatar
ryanlberg
ryanlberg is offline
Default key stuck in ignition
so my key wont come out of my ignition in any position. i cant figure out how to get it out any ideas. the bike runs fine just cant get the key i have tried everything bike is a 2007 nightster
Old 09-19-2011, 05:54 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
Tumblers are shot - ignition is broken. Buy a new one, or...........
Make an on/off toggle switch and hide it like I did for about $10. Fvck keys.
Old 09-19-2011, 06:02 PM
ryanlberg's Avatar
ryanlberg
you have pics of that
Old 09-19-2011, 07:21 PM
jockeyshiftjoe's Avatar
jockeyshiftjoe
jockeyshiftjoe is offline
"Get a Bigger Hammer" lol j/k the toggle switch method should be easy just splice into one of your wires either coming for your ignition switch or even your starter, and just pick up a two way toggle switch from an autoparts store, about $3.50 and simply splice that wire to the two connections to make a circuit along with a ground. lol don't laugh I just did it quick for reference. But here is my childish attempt at a diagram...
Old 09-19-2011, 07:26 PM
mikeallenbrown's Avatar
mikeallenbrown
mikeallenbrown is offline
I like that idea
Old 09-19-2011, 08:04 PM
GDixon61's Avatar
GDixon61
GDixon61 is offline
unless the switch is a lighted one you do NOT need a ground. If it is not lighted and you add a ground you will be making a direct short from +12 vdc to - 12 vdc and blow fuses or burn wires.
instead of my favorite saying "Baby go boom" it could be "baby lets burn"
Old 09-20-2011, 08:28 AM
cameraboy's Avatar
cameraboy
cameraboy is offline
this happened to me on my 82 Virago a few years ago. Only, I couldn't even turn the key. So I was stuck in a grocery store parking lot. I sprayed lots of WD40 into the lock. Dumped it in, nearly. And then, 3 minutes later, like magic... ignition turned, key came right out.
Old 09-21-2011, 11:10 AM
Sharkman73's Avatar
Sharkman73
Sharkman73 is offline
Get some Aero-Kroil and spray in there..it will loosen up the tumblers. Mine became difficult to remove and I did this and it loosened it up now the keys goes in and out effortlessly.
Old 09-21-2011, 01:02 PM
DavidStiebel's Avatar
DavidStiebel
DavidStiebel is offline
take the bike to a cobble stone road, lay the bike on its left side, take a BFH and hit the key (not the housing) hard, jump up and down on the gas tank.
Now take the bike, lay it on its right side, pour lighter fluid on the rear tire and light it.
If all the above will not loosten the key, tie the bike to the bumper of your 57 chevy and drag it down the road 400 to 500 miles, drop in an envelope and return to Harley Davidson, 405 SA drive, Bumfuk, North Carolina, 10101.
Hope this helps,
Old 09-21-2011, 01:11 PM
parabellum_9x19's Avatar
parabellum_9x19
parabellum_9x19 is offline
Agreed your tumblers have probably locked up.
I would:
1) Spray a good lube like AeroKroil in there and let it sit for a while.
2) If the key still does not come out, remove the igntion module from the bracket, and bang it back and forth on something like a 2x4 wrapped in a soft cloth....the goal is to free the stuck tumbler and allow the lube to get into every little internal pocket in the tumbler mechanism.
coo1breeze
05-14-2020 10:00 AM
PoPo75
06-19-2012 03:27 PM
rebbe18
03-25-2012 08:01 PM
YtseJam
08-08-2010 03:51 PM
F1J1
07-14-2007 07:28 PM
Quick Reply: key stuck in ignition
