Help with d01 thru d10 codes
Old 05-27-2016, 11:13 PM
pblanton2209's Avatar
pblanton2209
pblanton2209 is offline
Stage I
Default Help with d01 thru d10 codes
Hello everyone I'm new to the touring world. I have just picked up a 2002 ultra classic efi and trying to get all the little things fixed on it. But I have a few problems I cant seem to get fixed any help will be great. I have a d10set code on the speedo and cant find where to start of what needs to be changed out or repaired. Second one is it runs good cranks right up but when going down the road and you lay into the gas it starts to spits and skips and what I call misfire. got new plugs helped some. Its like its needing more gas or something. took fuel sending unit off and found the linner of the tank is coming off so I cleaned it the best I could and have a new fuel filter and lines coming just hoping that will fix it. but if anyone has had a problem like this or close please let me know the wife is ready to ride lol thanks
03 road king (03-13-2022)
Old 07-07-2017, 12:59 PM
Axeman10's Avatar
Axeman10
Axeman10 is offline
Stage III
Did you get any answers to your issues?
Old 07-07-2017, 06:40 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
After all the diagnostic codes are displayed, the speedometer's pulses per unit (PPU) setting is displayed. This number will vary depending on speedometer part number.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit"
also "CLR means clear.
Again, not my answer, copied from elsewhere a while back as a reference.
The following 2 users liked this post by bigskyroadglide:
Gooman11 (12-11-2020), Innigray (06-22-2020)
Old 07-08-2017, 09:53 AM
Axeman10's Avatar
Axeman10
Axeman10 is offline
Stage III
Thx for the quick reply
Old 07-08-2017, 10:55 AM
Axeman10's Avatar
Axeman10
Axeman10 is offline
Stage III
Has anyone having or had any issues as mentioned above, I'm having the same issues. Talked with a HD tech, and he informed me there is no codes shown above lol. The tech showed me the code book and sure enough the above codes are not listed. My 2000 softail is running great at idle, but once you put some throttle to it, head light dims, speedo light dims, speedo needle goes negative/under 0, runs rough, engine light comes on then it will run fine for a short time & cycle through this same scenario at a low throttle. On the road at higher throttle it will stall. Any advice would be greatly appreciated. I've changed the battery, plugs & wires & regulator. It's a carb not efi. Thanks again
Old 12-11-2020, 02:49 PM
Gooman11's Avatar
Gooman11
Gooman11 is offline
Stage IV
my speedo comes and goes with chk eng light also odometer goes out too did the speedo test hold in reset and turn on ignition codes I got are do15ee do25ee do85ee rest say clr sound like a speedo sensor or a wire problem Thanks Gary turn sigs wont cancel auto
Old 12-11-2020, 03:03 PM
Inop's Avatar
Inop
Inop is offline
4 year old thread......wonder if he got it fixed?
Old 12-11-2020, 04:43 PM
Gooman11's Avatar
Gooman11
Gooman11 is offline
Stage IV
Bigsky has info hard to find on internet let alone dealers I lucked onto this thru a search recently bought a 02 fxdl speed issues but knew it buying it decent bike just speedo issue most stuff I have owned didnt have newer ecm had a new 05 fxd but sold it before probs came along most my bikes have been shovels and evos. Inop do you have any thoughts on this thanks Gary
Grey_Beard
04-13-2019 01:40 PM
madmaxnj
04-07-2019 02:29 PM
dennisj1988
07-27-2018 01:50 PM
tbrown2
05-09-2009 11:49 PM
Twisted Humor
08-05-2007 03:22 PM
Quick Reply: Help with d01 thru d10 codes
