I've always put in a quart but was reading the owners manual and it says 38oz's. I've been doing to quart thing for years and years. And I know for a fact two dealers say a quart is what they use. Opinions?
Gary
Unless I'm mistaken, I think 38 oz is the amount specified for a complete drain, with the primary cover off, for instance. If I'm just changing the oil without removing the primary cover I just use a quart.
For the TC96 it's 38oz wet and 45oz dry with a complete drain (i.e. removing the primary cover, etc.) The best thing to do is fill it until it just covers the bottom of your clutch basket by about 1/2" or so. If you can do that with 32oz, kudos. I never can. I know it's a wet bath and the oil just gets slopped around in there so you may not have a problem with running 32oz but I just follow what the manual says.
