Changing Primary Oil
Old Oct 7, 2007 | 08:01 PM
Unclenuts's Avatar
Unclenuts
Default Changing Primary Oil
Hey Gang:
If I change my Primary Chain Oil why can't I addthe oilthrough the Primary Chain Inspection cover instead of the Clutch Inspection Cover like the Service manual says??
Thanks
Old Oct 7, 2007 | 08:04 PM
anubisss's Avatar
anubisss
Default RE: Changing Primary Oil
You can. That is how I do it everytime...
Taterdog's Avatar
Taterdog
You can, but it's very important to get the level just right, and you can only do that by removing the clutch inspection cover. Your owner's manual shows where the level should be.
Old Oct 7, 2007 | 08:13 PM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: Taterdog
And the manual also gives an amount.Some people just add in what the manual says.For an example the TC88 manual says 1 qt when the primary has just been drained but the picture shows the level up to the bottom of the clutch spring.This will take about another 4-6 oz. if i'm correct.
There are a lot of posts about this ,do a search.
Old Oct 8, 2007 | 06:12 AM
PapaTravis's Avatar
PapaTravis
I pull off both cover, to check everything out, and adjust the chain (if need be). There is no problem adding the oil through the chain inspection cover, but I leave the derby cover off just to check the level.
oldbikenut
Jul 16, 2015 06:40 PM
tonycap
EVO
38
Jun 1, 2013 06:39 PM
nemick
Aug 2, 2010 01:05 PM
larry5h
Jul 27, 2006 02:02 PM
crzrlou
Oil Archive (no new posts)
21
Jun 1, 2005 05:41 PM
