Fuel Pump pressurizing makes different noise
My '08 Ultra is making a different noise when I hit the run switch. Instead of the high pitched whine it now makes a lower pitch gravelly whine followed by a hissing sound like air leaving a tire that seems to be coming from the air filter area. The bike starts right up and runs normally but something has changed.
I thought it was my battery but the voltage looks right, does anyone have any ideas
08 - 6 years old - never changed the battery - If this is the case -
Just Saying!
noise
You may want to read this thread...this may be your problem:
(Induction module)
https://www.hdforums.com/forum/touri...om-harley.html
Here is what one of the posters said:
"Defective design.....instead of the gentle whine of te FI when you hit the start button, it sounds like Woody Woodpecker is trying to peck his way out of your aircleaner! Beware......if you hear this noise.....bring it to your dealer asap! Hopefully they have the part by then ! Hope it doesn't happen to you brother....or anybody else out there!"
(Induction module)
08 - 6 years old - Have you already changed the battery? DO A LOAD TEST ON THE BATTERY! After using the bike, the battery will have a surface charge on it showing "ample" voltage but if this is the case a load test will expose a weak battery.
Just Saying!
Just Saying!
There was a fuel filter canister recall on the 08s, was yours done?
Also could be a hole in the lines, I've heard of reports that they can wear through if they were not routed correctly.
Today is August 11, 2011
Yeah, they started building 2012 models a couple months ago. They have been selling them for almost a month now.
My '08 was built in June of '07 approximately 4 years and 2 months ago.
Now for your 5 year you are subtracting build date from the current model year.
2012-2008 = 4 years.
2011-2007 = 4 years.
I have no doubt that a battery can go bad in less than 4 years (I used to feel lucky if I got 2 seasons on a battery).
08-Nightster
Electrical/Lighting/Alarm
35
04-06-2019 12:30 PM
